Bu konuda 789 mesaj var
Bu arada ucuz versiyon olan Xbox Series S'te oyunlara ayrilan hafiza (7.5GB-8GB) , Xbox One X'ten (9GB) daha dusukmus, bu yuzden simdiki nesil oyunlari oynatirken Xbox One S versiyonunu kullanacak diyor Digital Foundry... Ornek olarak RDR, Final Fantasy XIII gibi oyunlari 4K degil, 720p oynatacak deniliyor...
According to Digital Foundry, who noted the Xbox Series S has less system memory available to titles than the Xbox One X (8GB vs 9GB), the cheaper Xbox will most likely use the Xbox One S versions of backwards compatible games.
That means games that were enhanced to support 4K resolution, such as Final Fantasy XIII, Red Dead Redemption and Sonic Generations, will run at their regular resolutions instead, which is often 720p.
“The Xbox One X has 9GB of system memory available to titles. The Series S has 8 [and] I’ve seen some reports that it’s actually 7.5GB,” said Digital Foundry’s John Linneman. “Regardless, with either configuration, it’s still lower than the Xbox One X, so I think it’s almost a full gone conclusion that the backwards compatibility will be drawing upon Xbox One S as opposed to Xbox One X.”
https://www.techradar.com/news/xbox-series-s-may-not-be-able-to-play-xbox-one-x-enhanced-titles-heres-why ] ...
[ Edit ] :
Microsoft confirms Xbox Series S won't support Xbox One X backward-compatibility enhancements
In response to a query from VGC, Microsoft explained that, rather than utilising existing Xbox One X enhancements, Xbox Series S will instead run Xbox One S versions of backward compatible games and apply its own enhancements in order to deliver "the highest quality backwards compatible experience consistent with the developer's original intent".
The exact enhancements offered by Series S will no doubt differ on a game-by-game basis, but Microsoft says players can expect to see "improved texture filtering, higher and more consistent frame rates, faster load times and Auto HDR".
https://www.eurogamer.net/articles/2020-09-11-microsoft-confirms-xbox-series-s-wont-support-xbox-one-x-backward-compatibility-enhancements ] ...
JardeL tarafından düzenlendi
https://www.bloomberg.com/news/articles/2020-09-15/sony-is-said-to-cut-ps5-forecast-by-4-million-due-to-chip-woes
Üretimi azaltmış Sony.
@JardeL hocam yanlış anlamayın da 4K var, 4K var. Örneğin, 4K'da elimdeki sistem ile bütün oyunları düşük ayarlarda 60 FPS alacak şekilde oynayabilirim. Şimd bu 4K ayarlar ile oynanan oyun ile RTX 3090 ile 4K'da bütün ayarlar en yüksekte ayarlı oynanan oyun arasında sizin de tahmin edebileceğiniz üzere dağlar kadar fark olur. O yüzden ben konsollardaki bu 4K, 1440p, 720p olaylarına pek güvenmiyorum açıkçası. Tabiki de benim sistemden güçlü olacak PS5 ve XBOX series X ancak insanın içine de kurt düşmüyor değil.
Ayrıca sadece 1 GB'lık bellek farkı ile 720p'den 4K'ya geçilebiliyorsa iyiymiş hakikaten. :icon_whistle:
Ne gerek var yahu 480p oynatsaymış.. :facepalm:
MS ise ticari basari acisindan yaklasti, hem en ucuz yeni nesil konsolu, hem en guclu yeni nesil konsolu sunan firma oldu. Segmentation ile yuksek satis, yuksek kazanc. 4K istiyorsan en guclu GPU, 1080p TV’deysen yine ayni “next-gen” oyunlari oynatacak ucuz bir makine.
Sony ise biraz daha kullanici deneyimi tarafindan yaklasti, ucuz konsolu da gercekten next-gen, o platforma ozel hazirlanan oyunlarin hepsi 16GB hafiza ve guclu GPU hedefleyecek, segmentation icin ortalama kalite dusmeyecek.
Yalniz Sony biraz son dakika overclock’lu gibi durup killandiriyor. Sessiz/sorunsuz oldugunu bi gormek lazim.
MS atari kartuslarini SSD teknolojisi ile geri getirecek gibi gozukuyor, pahali ama ilginc aslinda. Hot swappable, plug and play. Konsolu acip kapamak yok, birinden otekine gecebiliyorsun. Dikkat problemli hiperaktif muptela nesil bir oyundan otekine iki saniyede ziplayip 10 dakikada 20 oyun oynayacagim diye iki uc kartus alir.
Belki bu nesil bitmeden doku/asset streaming ile her sahnesinin kalitesi dolu dolu bir oyun yapip “special edition” seklinde kendi kartusunda satacak bi delikanli firma cikar, 1TB bir oyun yapar. GTA tipi ama asset’ler photogrammetry ile gercek dunyadan scan edilmis, gittigin yerin verisini arka planda yukleyen bir oyun hem bu konsollarin 16GB hafizasinin, hem de SSD’den o hafizaya dogrudan erisimin hakkini verir.
Mesela MS Flight Simulator siz uctukca arka planda veri indiriyor, goruntude level of detail degisimleri goruluyor. O oyunun manyagina “al 1TB kartusta butun veri hazir, 16GB hafizaya stream ederek hep yuksek kalitede calistiracagiz, GPU’nun nefesi yetmedigi icin internal cozunurluk 4K altinda ama binalar bi oyle bi boyle geometry pop-in ve texture pop-in yapmayacak, kalite hep yuksek olacak” desen alabilir mesela. O oyunu oynayacaginda tak kartusunu, ucak ilerledikce her an ekranda gorulecek veri 16GB’a sigacak sekilde en yuksek kalitede arka planda 1TB kartustan stream edilsin.
Zaten upscaler filan kullaniliyor, oyle 4K 60 FPS native her oyunda sanmiyorum... Series S sadece RAM degil GPU anlaminda da One X'in gerisinde oldugu icin "RAM ayni olsa da One X'in iyilestirmelerini oynatamaz" da deniyor... Ama tabii onun da SSD, CPU gibi bilesenleri daha iyi... Surada 1.5 - 2 ay kaldi, ortaya cikar pek cok sey...
Playstation 5 - $499
Playstation 5 Digital Edition - $399
PLAYSTATION 5 SHOWCASE
Final Fantasy XVI
https://www.youtube.com/watch?v=yr6PtdY0i7M
Hogwarts Legacy
https://www.youtube.com/watch?v=1O6Qstncpnc
Marvel’s Spider-Man: Miles Morales
https://www.youtube.com/watch?v=T03PxxuCfDA
Call of Duty: Black Ops Cold War - Trabzon Havalimanı
https://www.youtube.com/watch?v=mniWW2haNnY
Resident Evil Village
https://www.youtube.com/watch?v=7paVdAx3cjE
Oddworld: Soulstorm
https://www.youtube.com/watch?v=8OSFEL0PNYs
Five Nights At Freddy's
https://www.youtube.com/watch?v=DXiTt_6RbxQ
Demon's Souls
https://www.youtube.com/watch?v=jGUtTPRuGak
Devil May Cry 5 Special Edition
https://www.youtube.com/watch?v=4mT1N4yIYUo
Deathloop
https://www.youtube.com/watch?v=P8LPZ-Hjrkk
PlayStation Plus Collection
https://www.youtube.com/watch?v=iEsLzh0xLZc
PlayStation®5 Specifications
CPU
x86-64-AMD Ryzen™ “Zen 2”
8 Cores / 16 Threads
Variable frequency, up to 3.5 GHz
GPU
AMD Radeon™ RDNA 2-based graphics engine
Ray Tracing Acceleration
Variable frequency, up to 2.23 GHz (10.3 TFLOPS)
System Memory
GDDR6 16GB
448GB/s Bandwidth
SSD
825GB
5.5GB/s Read Bandwidth (Raw)
Optical Drive
Ultra HD Blu-ray (66G/100G) ~10xCAVBD-ROM (25G/50G) ~8xCAVBD-R/RE (25G/50G) ~8xCAVDVD ~3.2xCLV
PS5 Game Disc
Ultra HD Blu-ray, up to 100GB/disc
Video Out
HDMI™ OUT port
Support of 4K 120Hz TVs, 8K TVs, VRR (specified by HDMI ver.2.1)
Audio
“Tempest” 3D AudioTech
Dimensions
PS5: Approx. 390mm x 104mm x 260mm (width x height x depth)(excludes largest projection, excludes Base)
PS5 Digital Edition: Approx. 390mm x 92mm x 260mm (width x height x depth)(excludes largest projection, excludes Base)
Weight
PS5: 4.5kg
PS5 Digital Edition: 3.9kg
Power
PS5: 350W
PS5 Digital Edition: 340W
Input/Output
USB Type-A port (Hi-Speed USB)USB Type-A port (Super-Speed USB 10Gbps) x2
USB Type-C® port (Super-Speed USB 10Gbps)
Networking
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T)IEEE 802.11 a/b/g/n/ac/axBluetooth® 5.1
DualSense™ Wireless Controller Specifications
Dimensions Approx. 160mm x 66mm x 106mm (excludes largest projection) (width x height x depth)
Weight Approx. 280g
Buttons
PS button, Create button, Options button, Directional buttons (Up/Down/Left/Right), Action buttons (Triangle, Circle, Cross, Square), R1/L1 button, R2/L2 button (with Trigger Effect) Left stick / L3 button, Right stick / R3 button, Touch Pad button, MUTE button
Touch Pad
2 Point Touch Pad, Capacitive Type, Click Mechanism
Motion Sensor
Six-axis motion sensing system (three-axis gyroscope + three-axis accelerometer)
Audio
Built-in Microphone Array, Built-in Mono Speaker, Stereo Headset JackOutput : 48kHz/16bit, Input : 24kHz/16bit
Feedback
Trigger Effect (on R2/L2 button), Vibration (haptic feedback by dual actuators), Indicators (Light bar / Player indicator / MUTE status)
Ports
USB Type-C® port (Hi-Speed USB), Stereo Headset Jack, Charging Terminals
Communication
Wireless: Bluetooth® Ver5.1
Wired: USB connection (HID, Audio)
Battery
Type: Built-in rechargeable lithium-ion battery
Voltage: DC 3.65V
Capacity: 1,560mAh
PS5 Aksesuarlari ve fiyatlari
DualSense™ Wireless Controller (standalone) – US$69.99/CAD$89.99/¥6,980/€69.99 (RRP)
PULSE 3D™ wireless headset – with 3D audio support and dual noise-cancelling microphones US$99.99/CAD$129.99/¥9,980/€99.99 (RRP)
HD Camera – with dual 1080p lenses for gamers to broadcast themselves along with their epic gameplay moments US$59.99/CAD$79.99/¥5,980/€59.99 (RRP)
Media Remote – to navigate movies and streaming services with ease US$29.99/CAD$39.99/¥2,980/€29.99 (RRP)
DualSense™ Charging Station – to conveniently charge two DualSense Wireless Controllers US$29.99/CAD$39.99/¥2,980/€29.99 (RRP)
Oyun fiyatlari $69.99 :S - €79.99 :icon_eek:
PlayStation 5 Launch Day Games from SIE Worldwide Studios
Astro’s Playroom (Japan Studio) – pre-installed on PS5
Demon’s Souls (Bluepoint Games / Japan Studio) – US$69.99/CAD$89.99/¥7,900/€79.99 (RRP)
Destruction All Stars (Lucid Games / XDEV) – US$69.99/CAD$89.99/¥7,900/€79.99 (RRP)
Marvel’s Spider-Man: Miles Morales (Insomniac Games) – US$49.99/CAD$64.99/¥5,900/€59.99 (RRP)
Marvel’s Spider-Man: Miles Morales Ultimate Edition (Insomniac Games) – US$69.99/CAD$89.99/¥7,900/€79.99 (RRP)
Sackboy A Big Adventure (Sumo Digital / XDEV) – US$59.99/CAD$79.99/¥6,900/€69.99 (RRP)
Oddworld: Soulstorm
İlgimi çeken 2 oyun oldu.
Seneler sonra COD hizaya gelmiş gibi görünüyor. Battlefield ve Pubg dinamiklerini klasik COD hikaye anlatımı ile birleştirmiş. Oynanır gibi görünüyor.
Oddworld özel bir oyun,yapan adamların güzel kafası var.  Devamı her türlü oynanır.
PlayStation Plus Collection ile ps4 oyunları oynayabileceğiz sanırım da elimizdeki ps4 diskleri ile olacak mı acaba bu iş?
Ps4 kontrolcüsü ile Ps5 oyunu oynayabiliyor muyuz acaba?
Bizde gelen bir verginin kaldırıldığı veya azaldığı görülmemiştir. Bir vergi kaldırılıyorsa bilin ki başka bir isim altında daha büyüğü geliyordur. Ocak ayı gelince de tahminen 1 yıl veya süresiz uzatırlar.
Bu saatten sonra baş para vermem konsola..
Zaten tepe noktasını tsushimayla gördüm, yıllarca ondan daha iyi bir oyun gelmesi mümkün değil.
Bir oyuna 1000 tl para verecek kadar enayi değilim.
