Mesaj tarihi: Aralık 13, 2019 Bu bildiğin Silverstone FT03-MINI olmuş Altan Yoklar beğendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Aralık 13, 2019 Pazartesi gunu yazdigim soylentilerin cogunu dogrulamis Phil Spencer; Quote With the launch of the Xbox Series X, it's no surprise Microsoft has graphical capability on the mind. Spencer told us, "We wanted to have a dramatic upgrade from the Xbox One base console. So when we do the math, we're over eight times the GPU power of the Xbox One, and two times what an Xbox One X is." And when we do the math too, the Series X seems to be hitting around 12 teraFLOPs (the general metric used as shorthand to indicate graphics processing power). It's worth keeping in mind that hardware manufacturer AMD is leading the charge on the console's GPU/CPU, and the Series X will be capable of ray tracing for more realistic lighting, reflections, and shadows. Microsoft also has its eyes set on the future beyond launch day as it's accounting for 8K resolution down the line and 120Hz refresh rate. It's not all about GPU power alone--as expected, the Series X beefs up the CPU. Spencer explained, "On the CPU side, which is [something] we really wanted to push relative to previous generations, we have four times the compute power on the CPU in Project Scarlett." Admittedly, not much was given in terms of specifics, but whether or not the reference point is Xbox One's eight-core 1.75GHz CPU or One X's eight-core 2.3GHz CPU, Series X looks to be a significant upgrade. [ https://www.gamespot.com/articles/xbox-series-x-specs-twice-as-powerful-as-xbox-one-/1100-6472198/ ] ... Ozetle; Quote -12TF GPU; pushing to be "the most powerful console" -4x CPU speed of X1X -Designed to be as quiet/quieter than X1X -Dedicated share button on controller -Can pause/resume multiple games simultaneously -Full backwards compatibility Kasanin niye boyle devasa oldugunu da acikliyor aslinda bu ozellikler... GPU icin 12 TF demis ki bunun cekecegi guc ve sogutma gereksinimi, CPU'yu da dikkate alirsak az buz birsey olmayacak... PSU da bu kasanin icinde deniyor (Lockhart'da disinda olacagi soylentisi var) , en kotu ihtimalle bu buyuklukte bir kasaya mecbur kalmislar vey ihtiyatli davranmislar RROD vakasi yasamama adina... Resetera'da yeni nesil konsollarla ilgili bilgi veren ve takip ettigim kadariyla hepsi dogru cikan eleman "PS5 daha guclu olacak soylemimin arkasindayim" diyor... %10 civari gibi birsey soylemisti yanilmiyorsam... O da dogru cikarsa PS5 de devasa bir cusse ile gelebilir, sasirmamak lazim... Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Aralık 14, 2019 bu nesil ile konsollar tamamen pc leşti yani ? aslında ps3 cell faciasından sonra aklın yolu bu sanırım... Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Aralık 16, 2019 https://www.videogameschronicle.com/news/xbox-series-x-mock-up-images-compare-size-to-other-consoles/ Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Aralık 16, 2019 Ben bu boyut konusundaki eleştirileri pek anlamadım. Taşınan, oradan oraya götürülen bir şey değil ki, alıyorsun koyuyorsun televizyonun oraya, sadece tozunu alırken yerinden oynatıyorsun. Varsın büyük olsun. Ayrıca konsolların işlem gücü oldukça yükseldi, çift haneli terafloplardan bahsediliyor. Hal böyle iken bari büyük olsun da ısınma sorunları olmasın. Thustu beğendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Aralık 16, 2019 Bence tipi gayet salonda sub-woofer kamuflajlı göze batmıcak estetikte.. Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Ocak 25, 2020 xbox series x e ait olduğu söylenen görüntü.. YENİ XBOX Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Şubat 24, 2020 Yeni xbox'ın özellikleri belli oldu. https://news.xbox.com/en-us/2020/02/24/what-you-can-expect-next-generation-gaming/ Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Şubat 26, 2020 On 2/24/2020 at 15:27, wazzap said: Yeni xbox'ın özellikleri belli oldu. https://news.xbox.com/en-us/2020/02/24/what-you-can-expect-next-generation-gaming/ sony den halen açıklamadı... Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 6, 2020 https://www.eurogamer.net/articles/2020-02-24-microsoft-confirms-xbox-series-x-has-12-teraflops-gpu sony series x in 12 terafolps olmadı üzerine ps 5 in gücün arttırmak için resmi açıklamayı halen yapmadı diye salladılar konsol üssünde geçenlerde. bencede mantıklı. Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 8, 2020 (düzenlendi) @emre666 Bence mantikli degil. Yanlis hatirlamiyorsam PS4 cikacagi zamanlarda @ChipArchitect AMD’de calisiyordu ve eski forumda yazmisti. Projelerin aylar aylar once finalize edildigini ve en azindan cpu gpu tarafinda bir degisikligin son dakika mumkun olmadigini. Hadi ben yanlis hatirlayayim fakat mantiken PS5'i 9.5 tflops’dan 12-14 gibi rakamlara cikarirken tum konsolun dizayninin en azindan sogutma birimi icin degismesi gerekiyor. Birde bunun 2020 holiday sezonuna yeterli stokla satisa cikmasi var. Sony neden sessiz bilmiyorum ama nedeni o degil bence. Mart 9, 2020 Atrin tarafından düzenlendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 9, 2020 Bence Sony'nin aciklama yapmamasinin tek sebebi urun fiyati... Ellerindeki urunun maliyeti yuksek, eger kendileri cikip $499 gibi bir fiyat acikladiktan sonra MS (soylenilene gore daha iyi ozelliklerle) zarari goze alip $449'dan satisa cikaracagini aciklarsa kotu olur... Ama MS yuksek fiyatla cikarsa, ki benim tahminim $599, o zaman Sony'nin eli rahatlar... Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 9, 2020 (düzenlendi) Mantıklı. 1TB M2 Nvme SSD'nin fiyatı zaten yüksek. İlk satılan konsolları zararına satıcak bence iki firmada. Fakat fiyat belirtmeden Microsoft gibi özelliklerini açıklasınlar o zaman ? Benim tahminim PS5 (eğer tek model çıkarsa) 499 USD - Xbox Series X (iki model olacak diyorlar) Üst modeli 599 USD düşük modeli 399 veya 449 USD olur. 449 olursa ölümcül olur PS5 silip süpürür o yüzden 399 USD olur herhalde oda. Mart 9, 2020 Atrin tarafından düzenlendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 16, 2020 Xbox Series X'in özellikleri tam olarak açıklandı. Reveal hidden contents CPU 8x Cores @ 3.8 GHz (3.66 GHz w/ SMT) Custom Zen 2 CPU GPU 12 TFLOPS, 52 CUs @ 1.825 GHz Custom RDNA 2 GPU Die Size 360.45 mm2 Process 7nm Enhanced Memory 16 GB GDDR6 w/ 320mb bus Memory Bandwidth 10GB @ 560 GB/s, 6GB @ 336 GB/s Internal Storage 1 TB Custom NVME SSD I/O Throughput 2.4 GB/s (Raw), 4.8 GB/s (Compressed, with custom hardware decompression block) Expandable Storage 1 TB Expansion Card (matches internal storage exactly) External Storage USB 3.2 External HDD Support Optical Drive 4K UHD Blu-Ray Drive Performance Target 4K @ 60 FPS, Up to 120 FPS https://news.xbox.com/en-us/2020/03/16/xbox-series-x-tech/ Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 16, 2020 (düzenlendi) Xbox Series X Hands On, Gameplay & Controller! Xbox Series X Complete Specs + Ray Tracing/Gears 5/Back-Compat/Quick Resume Demo Showcase! Mart 16, 2020 emre666 tarafından düzenlendi epi beğendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 16, 2020 Canavar gibi olmuş bu sefer. Benim gibi konsollara uzak birisine bile güzel göründü. Konsollar PC'ye benzedikçe güzelleşiyorlar Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 Ozellikler cok iyi de fiyat ne olacak onu merak ediyorum... Kur boyle artmaya devam ederse 8-10bin TL'ye konsol aliriz artik... PS5 tarafina gelirsek; bundan birkac ay evvel Xbox Series X icin bu ozellikleri (52CU @ 1.82Ghz) ortaya atan (ve tutturan) eleman PS5 icin de 52 CU @ 2Ghz seklinde yazmisti... O da asagi yukari 13,3TF ediyor... Ama tabii genel bir "Xbox daha guclu" algisi oldugundan kimse dikkate almiyordu bu tarz soylentileri... Ayrica PS5'te daha fazla RAM oldugunu da soylemis... Ama basta da dedigim gibi fiyat mevzusu sikinti olacak gibi... Bir de dizaynini merak ediyorum PS5'in... Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 Yeni Xbox bencede güzel olmuş. Bu sefer cidden başlangıç için güçlü geliyor konsollar. Xbox'ın exclusive oyunları daha çok olsa almayı düşünebilirdim ama Sony'nin exclusiveleri daha çok ilgimi çekiyor şu an. Xbox'ta sadece Forza serisini oynayamadığım için üzülüyorum. Birde her zaman bir pc toplayıp xbox oyunlarını oynayabilme şansı var. Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 Ben de beğendim yeni Xbox'ı. Game Pass ile gayet mantıklı olabilir. Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 Fiyatı ne olur diyorsunuz da, yahu siz PC'ci adamlarsınız, konsol fiyatı iyi bir ekran kartı fiyatını geçmiyor ki emre666 and Whooosh beğendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 (düzenlendi) On 3/17/2020 at 11:10, CandleGarden said: Fiyatı ne olur diyorsunuz da, yahu siz PC'ci adamlarsınız, konsol fiyatı iyi bir ekran kartı fiyatını geçmiyor ki Doğru, söylenene göre yeni XBOX'ın RTX2080 ayarında grafik gücü var. 2080 bugün Amazon'da 800$. Geçmişte de bu hep böyleydi ama oyun fiyatları ve geriye dönük uyumluluk ve bazı teknik avantajları sayesinde PC uzun vadede her zaman avantajlı oluyordu fakat bu artık değişti gibi görünüyor. Abonelik sistemleri sayesinde konsollarda oyunlar eskisi gibi pahalı değil, görünüşe göre eski oyunlar ve aksesuarlar da yeni konsollarda kullanılabiliyor, PC'ye özgü hızlı loading, yüksek çözünürlük, yüksek kare sayısı, freesync vs de konsola geldi. Dolayısıyla yeni çıkan bir konsol bir PC oyuncusu için hiç bu kadar cazip olmamıştı. Peki ben evdeki oyun bilgisayarını kenera atıp bir XBOX alır mıyım? Hayır, gider yeni ekran kartı alır devam ederim ama oyun için sıfırdan bir bilgisayar alacak olsam işler değişebilir. Mart 17, 2020 Whooosh tarafından düzenlendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 Benim derdim sadece pahalılığı ile değil. Bir kere PC ile sadece oyun oynamıyorum ben, iş de yapıyorum, film de seyrediyorum, müzik de dinliyorum, internete de giriyorum. Ayrıca oyunlar her ne kadar yıllık abonelik ile ucuza gelse de yeni çıkan oyunlar ancak 1-2 sene sonra yıllık abonelere veriliyor. Üstelik steam gibi bir şaheser var, hem de Türkiye'ye özgü fiyatlandırması ile konsoldaki 400TL olan oyunu 200TL'ye alabiliyorsunuz. Ubisoft dötünü ayrı tutuyorum. Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 (düzenlendi) Cerny başgan yarın yargı dağıtabilecek mi acaba ? Quote Tomorrow at 9am Pacific Time, PS5 lead system architect Mark Cerny will provide a deep dive into PS5’s system architecture, and how it will shape the future of games. Watch tomorrow at PlayStation Blog: https://blog.us.playstation.com https://twitter.com/PlayStation/status/1239884910812450816?s=20 @wazzap hocam söylediklerinde çok haklısın ama @Whooosh'un dediği gibi benim mesela sıfırdan PC kurmam bu döviz kuru ile imkansız. Kendim için konuşuyorum tabiki ama takıntılı adamım. Hedefleceğim performans 2K 144hz olurdu. CPU'su GPU'su monitörü, ssd'si zart zurt ek olarak custom made su soğutması derken (hadi ilk etapta almasamda olur ama eskiden kullandığım bilgisayarım öyleydi neyse) 20.000 e çıkarım herhalde. Durum böyle olunca konsola devam. PS5 büyük ihtimal ile 500$ olucak. hadi 600$ olsun. yine kurtarıyor. 2013 yılında PS4 çıktı. amazondan sipariş verdim. 400$+130$ kargo gümrük ile geldi. amazon sonra nedense 100$ refund yaptı ben istekte bulunmasam bile. 10 kasım 2016'ya kadar 3 yıl kullandım. sonra o zamanın parası ile 950TL ye satıp amazon.de'den 1350TL'ye ps4pro aldım. çok şükür bozulmadı kullanıyorum hala. oyunlar evet pahalı ama kardeşlik falan derken ortak alınca onuda kurtarıyoruz. şu an güncel bir Sony oyunu 429 TL ye çıkıyor (bkz Last of Us 2) 429/2 = 215 TL ye oyunu alıyoruz eğer beklemek istemezsem. beklersem çok güzel indirimler oluyor o zamanda genelde 200-220 bandına düşüyor oyunlar. Jedi Fallen order'ı 229 deluxe edition olarak aldık mesela. Konsol pc'den iyidir asla demiyorum. Değil çünkü. Sadece Sony'nin exclusive oyunları ile playstation'ın espirisi oluyor. bir last of us bir god of war cidden oynanması gereken oyunlar. yoksa pc her zaman tercih. biraz bütçe meselesi. zamanında pc yi toptan satmasaydım belki bende pc ile devam ederdim. çünkü sürekli parça satıp alarak kendini güncel tutmak mümkün. fakat sıfırdan kurmak çocuk acısı gibi. onun yerine konsol alırım kalan parayla ikinci el motor alırım. Mart 17, 2020 Atrin tarafından düzenlendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 On 3/17/2020 at 13:53, Atrin said: (hadi ilk etapta almasamda olur ama eskiden kullandığım bilgisayarım öyleydi neyse) Hey gidi günler, ben hatırlıyorum senin sistemi. Fanlarını boyadığın cpu bloğunun vidalarını turuncu yaptığın sistemdi değil mi? Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
Mesaj tarihi: Mart 17, 2020 (düzenlendi) On 3/17/2020 at 14:33, ZvAnA said: Hey gidi günler, ben hatırlıyorum senin sistemi. Fanlarını boyadığın cpu bloğunun vidalarını turuncu yaptığın sistemdi değil mi? Aynen abi . 360'lık radyatör vardı. Swiftech Apogee GTX cpu bloğu vardı. ilk E6600 sonra Q6600'ı soğutuyordu. Pompamı falan hatırlayamadım ama kaliteli bir şeydi diye hatırlıyorum Hayalimde bir sistem vardı ona geçmek istiyordum. normalde bir firma bunu üretip yapıyordu ama istanbulda bir adam sebillerin kompresörünü mü ne çıkartıp yapıyordu. -80 dereceye kadar iniyordu alet. baya pahalıydı. Siyah bir kutuydu üzerinde mavi bir ekranı vardı derece vs bilgisi yazan. hatırlayan olur mu acaba? eski harddisk'i takıp fotoğraf aradım ama bulamadım. Bizim DHW Forumunda ya Ozan Abide yada başka birisinde vardı. Ozan Abi LN2 partileri yapardı ağzımın suyu aka aka fotoğraflara bakardım. Arada böyle hatırladıkça gaza geliyorumda artık evlendik ve yeni bir işe atılıyoruz zor bütçe ayırırım. edit: ahanda buldum. Vapochill by Asetek. https://www.youtube.com/watch?v=_ODV9p_R7zQ https://www.guru3d.com/articles-pages/asetek-vapochill-ls-review-(sub-zero-cooling),1.html Mart 17, 2020 Atrin tarafından düzenlendi Bu mesajı paylaş Bu mesajın linki Sosyal ağlarda paylaş
